Tutoriel Vidéo
apprenez à utiliser le logiciel de façon simple et rapide
Les Indispensables
  • Utiliser les touches de fonction : la touche [A]
    comment saisir un objet à une distance spécifique par rapport à un point
    définie précise fixée clavier mesures saisir mesurer
  • How to adapt the upper/lower building envelope profiles for custom wall shaping.
    How to shape the upper and/or lower profile of a building envelope to shape irregular forms
    wall roof ornamental wall
  • Objects for energy modeling, architectural and 2D graphics
    how to draw with energetic, architectural objects and detail the drawing with 2D graphics
    BIM horizontal curved dummy roof thermal bridge door window niche shaft pillar beam wall low wall slab ramp staircase overall dimensions canopy points lines polylines arches circles blocks images raster dxf measurements dimensions texts annotations labels
  • Identifying and assigning Thermal Bridges
    use of the identification functions for calculation and visualization of thermal bridges
    BIM view graphic visualizations box selection section linear transmittance filter ATLAS-PT TerMus-PT assigned identified
  • Defining the Building Energy Model and Zones
    How to define the building energy model, the thermal zones and how to assign them to rooms
    thermal zones, building to be calculated, subunits, heated zones, domestic hot water, heating, cooling
  • Defining schedules (Usage profiles)
    How to define a programmatic setpoint of temperatures, use of DHW and systems
    usage profiles, programming, scheduling, hourly, thermal zones, heated zones, domestic hot water, systems, temperatures, switching on, switching off, heating, cooling internal inputs
  • The definition of thermal power stations and plants
    How to define the HVAC and DHW systems and assign the served zones
    Thermal power plants heating systems domestic hot water ventilation cooling generation distribution zones switching on and off
