Create a project and define the contour data and the materials necessary to describe the thermal bridge
new file external internal designer object temperature colour element conductivity import TerMus
Drawing a Thermal Bridge representation
Drawing the Thermal Bridge model, assigning materials and defining the boundaries
contour border dxf dwg grid segment side unit of measurement edge node snap length reference plane adiabatic material
Creating a Thermal Bridge using the Wizard
Showing how to generate the Thermal Bridge model starting from predefined wizard models
new project multifunction toolbar representation layout diagram characteristic geometry thermal
Calculation and printing the Technical reports
Shows how to run a calculation, view the results, export them to TerMus and compose the technical report.
results transmittance thermal linear flux correct word processor export print RTF DOC html PDF
Mould growth risk assessment
Running a calculation, assessing the risk of mould growth and composing the technical report.
risults iso-therms temperature critical monthly temperatures
By accessing and using our website services you implicitly accept the use of cookies to improve navigation and show content in line with your personal preferences. Info OK
